Flights of Fancy
Burn and color a fall forest scene fit for any harvest celebration.
By Deborah Pompano
This soaring chickadee project is a perfect way to practice your burning and painting skills. Most of the design consists of basic line work, which you can enhance as desired with shading and your preferred blend of watercolor paints. My version uses vivid jewel tones to give the effect of a blustery, moonlit night in early November.
Burning and Painting
Place the pattern on the blank, and carefully follow the pattern lines using graphite paper and a pencil. Outline the large foreground leaves, stems, berries, and bird with a small writing nib on the medium heat setting. Using the same nib, reduce the heat setting and outline the smaller background leaves and the moon. Then use a shading nib to add depth to the feathers, face, berries, and leaves. Sign your work with a writing nib of your choice.
Add paint. Keep the watercolor paints somewhat diluted so your woodburned lines show through. Blot the paint with a clean paper towel anywhere the color is too thick. Once dry, spray on light coats of a clear satin lacquer. Display as desired.
Materials & Tools
| MATERIALS
• Basswood plaque, such as Walnut Hollow basswood country round: • Graphite transfer paper • Pencil • Watercolors, such as Winsor & Newton: burnt sienna, cadmium red light, cadmium yellow, cerulean blue, ivory black, Naples yellow, raw sienna, sap green, titanium white • Clean paper towels • Finish, such as clear satin lacquer |
TOOLS • Variable temperature woodburner with nibs: writing, shading • Paintbrushes: assorted
[button link=”https://1.shortstack.com/gMXJRg” bg_color=”#ff0000″]Download the Pattern[/button] |
